TEMPLATE EDITOR SUM OF LENGHT PARTS (part II)
hugo.pereiraR8323
Message 1 of 15
hugo.pereiraR8323
Hello!
@Sebastian_Eiche
Now i need to and more values to the previous  formula (ILength*IQuantity)
The formula (ILength*IQuantity)) is apply to the green boxes.
The formula of the grey boxes is ((../MUnitAmount-1)*5)
Its possible to join the 2 formulas?
The final result of the lenght, should be  for ex:
1000
2010
2110
2015
Is this possible?
I try to join the 2 formulas but it gives "invalid syntax"
Thank's
Replies (14)
Message 2 of 15
Sebastian_Eiche
how dou you try to join them?
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Message 3 of 15
hugo.pereiraR8323
I try to add "IFormula1+IFormula2"
Message 4 of 15
Sebastian_Eiche
Why don't you try a new combined formula?:
(ILength*IQuantity)+((../MUnitAmount-1)*5)
Sebastian Eiche
Message 5 of 15
hugo.pereiraR8323
don't work
Message 6 of 15
hugo.pereiraR8323
@Sebastian_Eiche
Formula in the pink boxes
why is adding !?
Message 7 of 15
Sebastian_Eiche
because it's summarize the formula3 of the field before.
Sebastian Eiche
Message 8 of 15
hugo.pereiraR8323
Sorry @Sebastian_Eiche , but i don't understand ☹️
Can you please take a look.
Message 9 of 15
Sebastian_Eiche
What should be the result of the pink boxes? could you create an excel or pic, what explain what you want to do?
I'm a litle bit lost in this thread, sorry
Sebastian Eiche
Message 10 of 15
hugo.pereiraR8323
See if this can help you, to help me...
Message 11 of 15
hugo.pereiraR8323
@Sebastian_Eiche , almost there...
(ILength*(IQuantity-1))+(5+ILength)+((IQuantity*5)-5)
Message 12 of 15
Sebastian_Eiche
ok good to see, until now I had no time to have a look
Sebastian Eiche
Message 13 of 15
hugo.pereiraR8323
Hello.
I'm back to this problem.
In the model i have some profiles.
My supplier only have this profile with 1800mm minimum lenght.
So one solution that i have is to weld the small parts in to oneassembly part that have more them 1800mm.
But, for each 2 profiles we have to add 5mm for the saw waste, ex:
1000 + 5 + 1000 = 2005mm final profile lenght.
The formula that we use is adding 5mm in the sinlge parts (F1 and F2)
And in the assemblys parts are 5mm less  (F3 and F4)
The correct lenght should be:
F1 - 4un - 4095mm
F2 - 6un - 7055mm
F3 - 1un - 4655mm
F4 - 4un - 3005mm
See the attach files.
Any ideias how to solve?
Is there a place to see how the template editor works?
Thank you.
Message 14 of 15
hugo.pereiraR8323
@Sebastian_Eiche , any idea?
Message 15 of 15
Sebastian_Eiche
I don't have time this week to have a look for this, but seems to be a problem which is easier to solve in an excel file
Sebastian Eiche
