Steel rafter to column
Hi All, i ve got a task to made this kind of connections, as i could not find any appropriate connections template I'm doing it manually for every single column:
Cut at object rafter as shown on picture 1 and after attaching end plates with a weld point.
Does anyone know how to simplified it ?
robertwmerriman1
Hi @Anonymous
To me that is more of an end - end plate connection.
If you use the "End plate splice" at least the system will model the plates, bolts & welds etc.
For the vertical cut and plate on the rafter you will need to do that yourself but you could then roll everything together to make a custom connection if needed
Rob Merriman, Technical Specialist / Principal Structural Designer, OLG
Thanks Rob for this solution,
it is working nice with same beam size, if like mine 254x146x37 to connect 152 column it is a bit difficult to adjust, but anyway it is very helpful for me for the future .
Cheers
