Running Dimension Text Size
simon_zeng_sq
simon_zeng_sq
Currently, the text size in relative and absolute dimension are same.
Is there any setting which can make the absolute dimension text size smaller?
Thanks.
johnjmbennett
Is there are any options, it would come from either the dimension style , which is set within the prototype, this is an Autocad function,  other settings for selection and use of the dim style come from the management tool defaults.
fractional dims use a combination of the style and MT settings for example.
I am not aware this is possible, I think only one text size is available as an option under the settings, I do not recall setting in the MT.
John Bennett
ArjunGaba
@simon_zeng_sq  Please open your prototype file and type ddim  then opening dimensioning style manager change text size in the Ddim Settings..  Also You can make different dimension styles to different dimensions by using this & Mt..
Sebastian_Eiche
please be careful  with the ddim command. This will open the "AutoCAD" dimension style manager which is not exactly the same like the Advance Steel dimension style manager:
They look similar, but they are not. We have issues in the past with the dimensionstyles which are changed with the AutoCAD dimension style manager, please use the Advance one for you changes.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
ArjunGaba
@Sebastian_Eiche  You have to use Setting of text via ddim . If you don't do that so how you will recall dim style in Management Tool Dimension style tab  for different types of dimensions.
simon_zeng_sq
Thank for your help. Actually, I only need these 3 figures smaller than the others.
