Steel frame column-beam gap
cv_simeonova
cv_simeonova
What's the typical gap (tolerance) you put in knee column-beam connection, so it could fit on site. And is there a document with recommendations?
sdonohoedesign
No tolerance.  In reality it is just going to bolt up together.
The only place you would usually build tolerance in is where you think something might not fit if manufactured slightly too long.
