Starting problem with Dynamo for Advanced Steel
Message 1 of 11
Hi, everyone! When I click dynamo for AS in add-ins, a dialog box shows up as in the figure. After I close the dialog box, I click the button again, dynamo can start, but the nodes won't work.
Can anyone help me with the problem?
THANKS!
Replies (10)
Message 2 of 11
In addition, the nodes in dynamo show warning as below:
The Warning: Point.ByCoordinates operation failed. Could not load file or assembly 'file:///C:\ProgramData\Autodesk\Advance Steel 2018\USA\Shared\Support\Templates\LibG.ProtoInterface.dll' or one of its dependencies.
Message 3 of 11
múinteoir
What version of Advance Steel and version of Dynamo are you running?
Múinteoir
The face of the BIM game | Former Autodesk Expert Elite | YouTuber | Lego Builder | Monaghan Man | Some Can, Some Cant
Message 4 of 11
Advance Steel 2018 and Dynamo Extension for Autodest Advance Steel 2018.
Message 5 of 11
I have installed dynamo 0.9.1, dynamo core 1.2.2, dynamo core 1.3.1, dynamo revit 1.2.2 and dynamo extension for autodesk advance steel 2018. Maybe it is the version problem? What should I do to solve it?
Message 6 of 11
múinteoir
i would uninstall all versions of dynamo then add only the version from Autodesk Account that is under Advance Steel.  Below is the version im running with no problems.
Múinteoir
Message 7 of 11
yurikim
Thank you for your posting @Anonymous
Try this to clean uninstall for DynamoCore:
https://github.com/DynamoDS/Dynamo/issues/7179
After this, install the Dynamo Extension for Advance Steel 2018.0.1 directly from the Desktop App.
Yuri Kim
Product Support Specialist, AEC
Message 8 of 11
This seems not to be dynamo extension for AS 2018, I cannot find the directory to download it. And I also use dynamo revit, if I uninstall all the dynamo programs, will the revit dynamo be affected?
Message 9 of 11
Message 10 of 11
Thanks for your reply, the program turned to be normal itself, I did not do anything. Maybe something was wrong in the program last time I started it.
Thanks all the same!
Message 11 of 11
Thanks all the same also!
