Can this be done with AS......I did this in AutoCAD.
Solved by AleckGiles. Go to Solution.
Hello yes it is possible, you have to use the macros or create the bars to make the assemblies.
I don't really understand the question, sorry if I answer it off...
You will have to model it manually. At this time, there is no macro to create such a rail.
Aleck Giles, Structures Consultant, Graitec
