Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
stair treads
stair treads
derrick_lambrecht
Message 1 of 12
stair treads
derrick_lambrecht
Shown below with red lines, is there a way to make all the treads to have a 1" overlap and keep the same spacing other than the top step?
Replies (11)
Message 2 of 12
acbsdesign
Hi @derrick_lambrecht
Nosing points will always be kept spread evenly along the nosing line so probably a better way is to make the top tread / grating a "cover" from the macro or just copy one tread and modify it.
Here we can define the nosing point offset (4):
Here we can position the top of grating at the landing:
Hope this helped at least a little bit.
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
Message 3 of 12
acbsdesign
@derrick_lambrecht
Reading now the first part of the question-usual slope and run is 11" and 7", but this is depending on the applicable Building Code.
If we use 12.125" wide treads this will cover appr. 1" nosing point over the lower sitting tread.
The example below is with grating treads:
And an example with concrete fillet pan treads:
It takes a few minutes to save certain tread type and dimensions in Step size, Tread Type, Tread dimensions 1 and 2.
After that save the entire macro in the library so it can be used all over again.
Have a great day.
Message 4 of 12
derrick_lambrecht
Thank you, unfortunately we have to go by the standards to maintain a 1"  overlap. I kept adjusting the length as specified, but it adjusts them so the top step is different than the bottom one. When I get the top overlap to be 1" the bottom one decreases.
Message 5 of 12
mick-CNF
What are you adjusting that makes them different?
Do you want all the overlaps to be the same?
If this information solves your problem please accept as a solution.
Message 6 of 12
derrick_lambrecht
nothing shows up with the attached file. yeah, I am trying to make the overlaps all be 1" to meet code standards
Message 7 of 12
mick-CNF
Are you using AS2022 or another version?
Message 8 of 12
derrick_lambrecht
Message 9 of 12
acbsdesign
The nosing points will spread evenly even if you offset the top tread.
(BTW-this makes sense per code)
If for some reason you need to offset ONLY the top tread-then we can use the Landing cover, or just copy one tread with the bolts and modify.
HTH.
Message 10 of 12
mick-CNF
Not 100% sure what you are doing but for me I never use the landing cover.
I create top tread, make it different then change the values in tread dimensions 1 and 2.
Overlap | Advance Steel | Autodesk Knowledge Network
Message 11 of 12
derrick_lambrecht
I made the top step different as requested. still need to make some adjustments someplace, but I think thats the right track to go on. Thanks!
Message 12 of 12
mick-CNF
My top tread size was already set, to extend it look at tread width on tread dimensions 1.
