Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Stair treads not exporting to Revit
1 REPLY 1
markhubrich
340 Views, 1 Reply
I cannot get my treads to play friendly with Revit. Both software 2021.
I got everything else to transfer except special parts and the pans. Strange thing is that I made the landing pans from bent profiles similar to how stair pans are made.
...and fix the kiss export issues.
Tags (4)
Labels (1)
1 REPLY 1
Rob_Merriman
in reply to: markhubrich
Hi @markhubrich
I had the same issue when I was doing an Advance Steel / Revit presentation, sent the issue to Autodesk and they can replicate, see article below
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
The only way to get the in would be to copy them to a new AS model with the special parts, explode to solids and then import or link the DWG into the Revit file
https://knowledge.autodesk.com/support/advance-steel/learn-explore/caas/simplecontent/content/transf...
Rob Merriman, AEC Technical Lead, Graitec
