hI @dcubbedge
Ive opened your NC file in the free NC viewer I use and the part looks ok, different NC viewers will interpret this information and display it differently, which seems to be the issue you are having.
There is one management setting that seems to help with beams with double cuts as you have at the end of your stringer. If you check to see if you have the "Force beam contours in NC" ticked, if you dont can you tick it, re-run the NC and see if that helps with the NC file.
There is one steel supplier in the UK for example whos machine reads the NC file in one way and when that management tool is enabled it reads the file the "correct" way.
The only thing this default seems to do is take some of the contour data which is in the lower part of the NC file and duplicate it and add it to the top of the NC file
Rob Merriman, Technical Specialist / Principal Structural Designer, OLG
