Using AS 2019
It may be hard to se in the attached rendering, but I have had to add 1/2" sq bar stock all around the inside of the handrails. I have had to shorten every picket one at a time in order to show this correctly. Every time I update the railing system the trimmed pickets go revert back to the original state (the trims are all removed)
So two questions:
1. Is there a way to trim the pickets as a group instead on one at a time?
2. Is there a way to save the railing so that the pickets do not revert back?
I have attached the file if that helps. Thanks!
Solved by mick-CNF. Go to Solution.
Your last post was 1.5" from the end of the beam, so change to 0 which moves the post, then change the move end base point to -1.5" which moves it back to where it was.
Within the power pack railing macro there is a lengthen/shorten setting for the pickets. I have used this many times and have had success with it. It works perfectly for rails that are dead flat. The railings that our company makes for stairs and ramps are made of a 3/8x3 flat bar frame, with 1/2 sq stock pickets. This was tricky to figure out as everything defaults to pipe rail. Our pickets and flatbar always have square cut ends regardless if flat or sloped. For sloping rails, I used the cut into feature to achieve the square cut on the pickets and again used the lengthen/shorten feature to cut them square in the correct spot. The cut into feature works just like a wood workers mortise and tenon joint. I know that eventually the connection box will be deleted as I cannot get some rails to 100% complete with the macro. The cut features will be removed once the connection box has been deleted. The downfall to using the lengthen/shorten picket is when you have a sloped top bar meeting a flat top bar on stair rails. The pickets on the flat follow what was entered into the cut into feature, but manually modifying (5) pickets instead of (60) is a no-brainer decision. Please reach out if any of this is not understood, I have never been the best teacher. After 5 years of adance steel. I have finally made the time to figure out stairs and railings with the macro's.
We have been building railings from 2D cad drawings for way to long. Our fabricators could care less, as long as they are accurate and can be built. Using advance, however, will allow us to automatically generate lists and bills of materials and start accounting for the materials instead of doing it the caveman way. It becomes a linear footage game for us to purchase sticks of material. Between the 1/2 pickets and the 3/8x3 flatbar, we use an ungodly amount i'm sure.
1. for me it would be really helpful to have a model or drawings to understand what you describe.
2. Are you happy with the Power Pack or is there stuff that is missing?
Agreed, screenshots would be helpful.
I don't know if this is asking for a solution to a problem or pointing something out.
I have the Powerpack and am happy to try to help anyone else who has it.
Can you do a screenshot of what is happening to see what you are doing and why the flat bar is wrong?
You mentioned something about cutting and deleting the joint box.
I try to avoid deleting the joint and use other features to cut but have them in a group.
With the profile could not be found have a look here.
