Stagger bolt option of gusset plate joint
sh.yuL6HC4
Message 1 of 11
sh.yuL6HC4
As below attached screenshot, we will put stagger bolt type in gusset plate joint. However, there is no option in gusset plate joint, do you have another way or joint?
Thanks for your help.
David Yu
Technical consultant
Linetek System
[email protected]
http://www.linetek.co.kr
Replies (10)
Message 2 of 11
Jonathan3891
For something like this, it might be easier to turn off the bolts in the connection properties and manually add the bolts.
Jonathan Norton
Blog | Linkedin
Message 3 of 11
sh.yuL6HC4
Thanks for replay. it will be alternative one.
However, still remain issues
In the joint macro, input 0 on bolt numbers, then unable to control gusset plate size.
Another one, stagger bolt option is not on manual bolting.
We are still doing condition by condition, there are many different bracing angles. pain
David Yu
Linetek System
[email protected]
Message 4 of 11
chrisengg
There is an alternate answer here, use regular connection
then remove bolts manually & use below
However i have seen 11 bolts in your connection, this works only for even nos. of bolts
Message 5 of 11
bigcarl5000kg
Hi @sh.yuL6HC4 ,
look at this idea: https://forums.autodesk.com/t5/advance-steel-ideas/custom-connections-odd-even-number-of-bolts-amp-s...
My current procedure is that I create the even number of bolts through the Bolts on beam tool and the last bolt manually, but this isn't 100% what we need.
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
Message 6 of 11
sh.yuL6HC4
Yes right
thanks
David Yu
Linetek System
[email protected]
Message 7 of 11
sh.yuL6HC4
thanks for idea.
stagger and slot hole are required in many cases.
I could say options are available on common connection
David Yu
Linetek System
[email protected]
Message 8 of 11
sh.yuL6HC4
Need to add this option in more joint macro.
It is possible to create with several steps, however unacceptable works. pain, too much time for modeling.
1. create bolt with macro, correct distance settings
2. delete macro box
3. Set UCS along angle bracing
4. Create bolts
5. Split bolt group
6. Set UCS
7. Move one row of bolt as stagger type
8. Delete last one bolt
David Yu
Linetek System
[email protected]
Message 9 of 11
bigcarl5000kg
@sh.yuL6HC4 ,
or create two separate lines with a different start  distance and different number of bolts (even / odd) ... in your case two separate groups
Message 10 of 11
sh.yuL6HC4
thanks for further help, yes it will be another way.
Nevertheless we should delete macro and manual work
David Yu
Linetek System
[email protected]
Message 11 of 11
bigcarl5000kg
Use the 2x the macro "bolts on beam" (one row each time) if possible and create two separate bolt groups by that with different settings
