Hi everyone,
Is it possible to make a list on SP dwgs with more than one SPdetail on a dwg, with the following format
(similar to quantity per assembly, but SP grouped under Phase):
PHASE 1
SP1 x
SP2 x
SP3 x
PHASE 2
SP1 x
SP2 x
SP3 x
Spent quite a bit of time, but couldn't get it right.
Thank you.
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
Solved by gabriel.costin. Go to Solution.
Try attached list and see if it works. It's done with AS 2020 version.
Gabriel Costin
@gabriel.costin wrote:Hello,
Gabriel Costin
Thank you,
You are the best 🙂
Have a great day.
