SMLX file from Robot 2023 isn't working on Advance Steel 2023
vanderson.mapdata
Message 1 of 8
vanderson.mapdata
Hello everyone!
I'm working in a structure developed with Robot 2023 and I'm not able to open SMLX file in Advance Steel 2023. The attached video shows the SMLX file generated with Robot and opened Advance Steel 2023 that has no errors and nothing is imported.
Please, let me know if you have any idea how to solve this in my machine.
Thanks in advance
Regards
Accepted solutions (3)
Replies (7)
Message 2 of 8
AntDrt
Can you try to import With the import from revit button
And can you attach the robot file ?
Antoine
AMG Fechoz
Serrurerie & Equipement Scénographique
www.amg-fechoz.com
Message 3 of 8
vanderson.mapdata
Hi @AntDrt
Thanks for your answer!
I tried with Import from Revit button, but it didn't work as well. Please see attached video.
I realized that both button (import from Revit and Advance Import) activate the same command: _AstM4CommGREXModelToAstor
Follow Robot file and SMLX file generated from Robot
Thanks in advance
Message 4 of 8
AntDrt
got no problem by my side,
did you tried to reinstall the RSA to AS plugin ?
Antoine
AMG Fechoz
www.amg-fechoz.com
Message 5 of 8
vanderson.mapdata
Hello @AntDrt
Thanks for testing my file and give me feedback
Advance Steel 2023 was uninstalled and installed again with Hotfix 2, but still not working.
Do you have any procedure to make a clean uninstall of Advance Steel 2023?
Regards
Message 6 of 8
bigcarl5000kg
hi @vanderson.mapdata ,
use some special tool for uninstall, eg. Total Uninstall, etc. It removes really many files/directories/registry entries, which Windows uninstallation cannot handle. Pay attention to what they offer you to remove.
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
Message 7 of 8
AntDrt
Hello @vanderson.mapdata  you may try to uninstall/reinstall only the robot addin.
Not just advance steel
Antoine
AMG Fechoz
www.amg-fechoz.com
Message 8 of 8
vanderson.mapdata
Thanks a lot @bigcarl5000kg and @AntDrt to help me with this trouble in my computer.
I used Total Uninstall to uninstall Advance Steel 2023 and AutoCAD 2023. AutoCAD 2023 and Advance Steel 2023 were reinstalled and now it's being working well.
Now I'm able to open SMLX file with Advance Steel 2023
@AntDrt , it wasn't necessary to reinstall the Robot addin
