Slotted holes dimmensioning
lipskiszymon
10,248 次查看
12 条回复
1 条消息(共 13 条)
lipskiszymon
Is there any option to set Slotted holes dimmensioning and labeling like in the attachment?
0 个赞
10,249 次查看
12 条回复
回复 (12)
2 条消息(共 13 条)
crydee-AG1
The token for the slot width (W) is Bolt Diameter and the slot length L is Length. So the label should say "Ø%Diameter x %Length Slot" or similar.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
Autodesk Certified Instructor - Gold
0 个赞
3 条消息(共 13 条)
lipskiszymon
Thanks but it does not solve my problem.
I would like to achieve dimensioning and labeling like in the first method (attachement),
Now I have the second one.
0 个赞
4 条消息(共 13 条)
crydee-AG1
Is your slot a hole made by a bolt or hole command or is it a polygon contour made by one of the contour features. You can only get the lower image if the slot is a contour. If it is a hole you can try playing with the Default > Drawing Dimensioning > General > Slotted hole dimensioning configuration.
LinkedIn
5 条消息(共 13 条)
lipskiszymon
There is no such option.
0 个赞
6 条消息(共 13 条)
crydee-AG1
已接受的解答
That is the option you show in your picture. Different builds have slightly different names.
LinkedIn
0 个赞
7 条消息(共 13 条)
lipskiszymon
It only changes dimensioning not labeling (atachment) so it does not solve my problem.
Taking opportunity, why the vertical location of the hole is not dimensioned?
0 个赞
8 条消息(共 13 条)
Drawtech
已接受的解答
If you want the label to use the hole centre dimension for the length you can use some vbscript to modify the value:
Try this for the label definition:
%BoltCount No. %Diameterøx%%script(LenTotal = %Length: LenCtrs = LenTotal-%Diameter: appendstring LenCtrs)ctrs slotted holes
I use vbscript in many of my label definitions to get the output that I want. 🙂
Dave Gronow
Drawtech Services Ltd
9 条消息(共 13 条)
lipskiszymon
Thanks a lot! That works!
What about vertical dimension of bolt localization?
I've added an internal Y dimension request similary to the internal X direction but it does not work.(attachment)
0 个赞
10 条消息(共 13 条)
Drawtech
已接受的解答
That Y dimension request is only giving the system points of the holes and nothing else - hence no dimension.
It needs the extreme points of the plate as well.
Not sure what is under the X dimension request that you have marked?
If it only contains the holes, this is not the request giving your X dimension and must be one of the other dim requests!
Dave Gronow
0 个赞
11 条消息(共 13 条)
lipskiszymon
Thanks a lot !
I've found the mistake in default settings (atachment).
0 个赞
12 条消息(共 13 条)
Julio_Soto
is it possible to learn this scripting power?
0 个赞
13 条消息(共 13 条)
Drawtech
Yes! ...I taught myself through a few online resources and a lot of trial and error!
Once you have a few working examples, it's easy to create others by changing the variable names and tokens to suit and standard VBscript functions:
https://www.w3schools.com/asp/asp_ref_vbscript_functions.asp
Dave Gronow
0 个赞
