Slotted holes dimmensioning
lipskiszymon
Message 1 of 13
lipskiszymon
Is there any option to set Slotted holes dimmensioning and labeling like in the attachment?
Accepted solutions (3)
Replies (12)
Message 2 of 13
crydee-AG1
The token for the slot width (W) is Bolt Diameter and the slot length L is Length. So the label should say "Ø%Diameter x %Length Slot" or similar.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
Autodesk Certified Instructor - Gold
Message 3 of 13
lipskiszymon
Thanks but it does not solve my problem.
I would like to achieve dimensioning and labeling like in the first method (attachement),
Now I have the second one.
Message 4 of 13
crydee-AG1
Is your slot a hole made by a bolt or hole command or is it a polygon contour made by one of the contour features. You can only get the lower image if the slot is a contour. If it is a hole you can try playing with the Default > Drawing Dimensioning > General > Slotted hole dimensioning configuration.
LinkedIn
Message 5 of 13
lipskiszymon
There is no such option.
Message 6 of 13
crydee-AG1
That is the option you show in your picture. Different builds have slightly different names.
LinkedIn
Message 7 of 13
lipskiszymon
It only changes dimensioning not labeling (atachment) so it does not solve my problem.
Taking opportunity, why the vertical location of the hole is not dimensioned?
Message 8 of 13
Drawtech
If you want the label to use the hole centre dimension for the length you can use some vbscript to modify the value:
Try this for the label definition:
%BoltCount No. %Diameterøx%%script(LenTotal = %Length: LenCtrs = LenTotal-%Diameter: appendstring LenCtrs)ctrs slotted holes
I use vbscript in many of my label definitions to get the output that I want. 🙂
Dave Gronow
Drawtech Services Ltd
Message 9 of 13
lipskiszymon
Thanks a lot! That works!
What about vertical dimension of bolt localization?
I've added an internal Y dimension request similary to the internal X direction but it does not work.(attachment)
Message 10 of 13
Drawtech
That Y dimension request is only giving the system points of the holes and nothing else - hence no dimension.
It needs the extreme points of the plate as well.
Not sure what is under the X dimension request that you have marked?
If it only contains the holes, this is not the request giving your X dimension and must be one of the other dim requests!
Dave Gronow
Message 11 of 13
lipskiszymon
Thanks a lot !
I've found the mistake in default settings (atachment).
Message 12 of 13
Julio_Soto
is it possible to learn this scripting power?
Message 13 of 13
Drawtech
Yes! ...I taught myself through a few online resources and a lot of trial and error!
Once you have a few working examples, it's easy to create others by changing the variable names and tokens to suit and standard VBscript functions:
https://www.w3schools.com/asp/asp_ref_vbscript_functions.asp
Dave Gronow
