Sloped beam not showing in elevation view
justinzammit
justinzammit
got an issue with the elevation views not showing sloped beams. Beams show in plan view.
currently using 3- Elevation view - Full. I have extended the view depth to unlimited.
Any suggestions?
Lewk_PSB
Go into the Drawing Style Manager and for 3 - Elevation View in the User section turn all of the Geometric Restrictions for the Model Objects to ALL. 99 times out of 10 you'll want to see everything in the view, so might as well not have any restrictions on them, right?
Lewk_PSB
Note: Only the User section can be edited. The Advance Steel drawing styles are basic templates to work off of and cannot be edited or deleted. Make sure that you are using the User profiles in your Drawing Style and Drawing Process palette, as well (click on the country flag at the top to toggle AS or User).
justinzammit
Thank you, saw the first step on here but didn't realize I had to switch profiles. Looks like it's working now.
