How to change/Add concrete beam sizes in AS2017.
Solved by AleckGiles. Go to Solution.
cannot manually edit the beam size in the property window ?
What @AntDrt is trying to say is..... Click in the white space at the end of the size text. Then this will become editable text. You will have a speech bubble above the text showing a formula. The first character or two is a shape code. After that the letters refer to the dimensions in the picture. Edit the text to enter the required dimensions following the formula in the bubble. If using a metric system then the units default to cm (I don;t know about "English" units).
Press return when done and the member changes size.
Aleck Giles, Structures Consultant, Graitec
