Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
single parts showing on assembly drawing but not on part drawing
6 REPLIES 6
1219 Views, 6 Replies
I have a single part (a plate) that shows up in my assembly drawing but it's no where to be seen detailed in any part drawings.
6 REPLIES 6
mick-CNF
Is it on an assembly with parts drawing and then you are trying to create a part drawing?
It won't create a part drawing if one has already been created on another drawing.
Screenshot 2021-05-10 150904.pngScreenshot 2021-05-10 151639.pngScreenshot 2021-05-10 151940.png
If this information solves your problem please accept as a solution.
I have this plate (p43) at the top of two posts, and at the bottom of my platform that bolt together. the plates show up on both these assembly drawings (I've attached an image, but again doesn't show up on parts drawing, if I picked a assembly drawing with parts, then why does base plate (bp1) on the column show up on parts drawing but p43 doesn't?
mick-CNF
Select the plate, right click and see if show part detail is available, if it is click it and the drawing the part is on will open.
If it isn't there is no part drawing.
in reply to: mick-CNF
So there is no option for show part detail. that means I have to detail the part from the assembly drawing?
mick-CNF
Can you attached the model?
mick-CNF
You can do it from the model.
https://knowledge.autodesk.com/community/screencast/7841cd95-251e-4579-8148-577b9b708d45
