- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
When I use the numbering function on my modeling, I choose only single parts marks. That is because all beams should be considered as Standalone Parts, and before I change the defaults for Standalone parts drawing I couldn't even make single parts drawings of them. The problem is that when I set labels for part mark for beams, some of them just don't have any part mark assigned to it on the label. Then I opened the beam properties and I found that they have single part marks assigned to them, but the "assebmly" box is checked and not the single part one, even though there are no assembly mark. so I supposed that this is why the labels do not find any marks. How can I change these beam properties in a way that they will all be recognized as single parts and have their part marks assigned and labeled correctly?
Thank you!
