Is there a way to show only red lines of my beams?
or a command that make Autocad lines from beams?
What do you want to do?
You could filter all beams... right mouse button...Advance property...then have a look in the view styles. There's one called symbol, which only show the system line and a little bit of the beam. But this is not only the system lines.
The question is, for what reason do you want to use it. In the most cases the users ask for this to transfer the model to another software. And therefore there are many other ways in the import/export tab.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
I need to attach the lines as external reference
Because i create a Dynamo script that create beams from lines and then i should use the lines only,
Is there a way to create Autocad lines via dynamo and Advance steel?
the dynamo add on for Advance Steel could be used with every command.
By creating beams, you had to set coordinates for the start and Endpoint, so the part of creating lines should be work without problems. But I'm not so familiar with Dynamo
Sebastian Eiche
