SHEAR STUD - MODEL ROLE
engineeringRVY5N
engineeringRVY5N
Hi All ,
I would like to assign Model role for shear stud as shear stud .
but in the drop down menu , i could not find the  shear stud . Please refer the snap and advise how to do it
johnjmbennett
Please check it is not listed under all category , from the drop down list. If not then go to management tools and look options there to add a model role into the system, you can see all the model roles that are currently in the system listed. Please see this faq: https://graitec.com/uk/resources/technical-support/documentation/technical-faqs/faq-2476-how-is-a-ne....
John Bennett
bigcarl5000kg
Hi @engineeringRVY5N,
in Mangement Tools are these predefined model roles for studs:
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
