Several company cartridges (prototypes)
orasquier
Message 1 of 22
orasquier
Hello, I would like to know if there is a simpler method than changing the prototypes in the folder to have several choices of companies when drawing up plans. For the moment I copy / paste the prototype of A to make the plans of A. Then I delete the prototypes A to paste those of company B.
For example a layout button?
Thanks in advance for your help
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Accepted solutions (4)
Replies (21)
Message 2 of 22
Ignus.E
One alternative can be as per below
By project
If the prototypes are in the model folder created automatically by Advance Steel, the location is set by the project.
For example, if the model file name is drawing1.dwg and it is saved on the Windows drive in ...\MyDocuments\Project\ClientA\Model1.dwg, then the prototypes are located in ...\My Documents\Project\ClientA\Model1\Prototypes.
This option allows having different prototypes for different projects.
Message 3 of 22
dave_conibear
I do the same.........I work for maybe 4 or 5 different companies.......I have a general work folder, and within that.....i have a seperate folder for each company.........and within each one of those I have a "New Model" which contains
(I re-name the above with whatever the client wants in the way of Job No)
and within "New" there is
Obviously the prototypes here are specific for each client........and that's how it works for me
Message 4 of 22
orasquier
Thanks for your answers, but I don't understand how to target prototypes other than the default: C:\ProgramData\Autodesk\Advance Steel 2025\FRA\Shared\Support\Prototypes
Message 5 of 22
dave_conibear
as long as you have the folder structure set up as I show......AS will find them
In the first instance you may need to select Model and NOT Shared
Message 6 of 22
dave_conibear
my file structure is
C:Work/client folder/new model/..............then as i showed you before
Message 7 of 22
orasquier
What menu are you in? I don't recognize this window.
Message 8 of 22
dave_conibear
Olivier....check your PM's
Message 9 of 22
Tomislav.Golubovic
I did a video on this a couple of years ago. I make a new "country" configuration for each client and then I change the prototypes in that Client's (country) folder. There's some registry editing to do, but you get a client list that opens up when you start AS.
https://www.youtube.com/watch?v=TcYzca2xC0U&t=262s
Message 10 of 22
orasquier
Thanks for all the answers, I succeeded for the plans, now I have to configure the lists 🙂
But isn't it too heavy to have all the prototypes copied in each project? Do you delete them afterwards?
Message 11 of 22
orasquier
This tip is amazing! To have the lists, different plans from the opening without copying, pasting.
Thank you very much
Message 12 of 22
dave_conibear
this is my list of prototypes for each model.............obviously i dont use all of them on every project........but they are there if I need them............I don't think 3 or 4 Mb is too heavy
Message 13 of 22
dave_conibear
I do the same for the lists..........I have 6 lists......Material (Sections)........Material (Plates) ........Delivery List.......Bolt List.......Assembly List & Anchor List....all the same for every job except the client logo / name
Message 14 of 22
orasquier
Interesting, where is the database to manage the lists? it must be copied into which folder -> Databases?
Because I am currently using the default lists user model. Project model is empty.
Message 15 of 22
dave_conibear
open the BOM Editor.......
choose the taqmplate you want to modify
right click on it and "Save As".........then modify as you need..........it will always be there
choose the template you want to use
Message 16 of 22
orasquier
But Advance necessarily uses the project list and not the user list, is that correct?
Message 17 of 22
dave_conibear
those lists are global.......not unique to the project.......once you have modified the ones you want..thay will always be there regardless of project
Message 18 of 22
orasquier
So for the lists you have to make copies with the company names.
So the version by country is lighter in the list window
Message 19 of 22
dave_conibear
......yes.........it's what I have done..........I have maybe 36 lists (for 6 different clients) all the delivery lists are the same except for the logo.....all assembly lists are the same except for the logo.....all bolt lists etc etc etc
I find it works best for me that way........and clients like to see a little personalization 😊
Message 20 of 22
Flies-Eyes
There are a few different ways to manage this issue.
My recommended solution is to run a different set of databases for each customer.
