set the same length for selected beams
jeromenowe
jeromenowe
Hello all,
Maybe a noob question, but, is it possible to change the length so that all selected beams will have the length after?
If yes, can you give me the trick?
Thanks a lot.
ChristianBlei
I dont think you can edit the length of beams by editing their properties.
If the situation allows (parallel beams) you can use AutoCAD "stretch" or
As "AstorTrimExtend".
HTH,
Christian Blei
Christian Blei
CBT Christian Blei Tools
christianblei.de
youtube.com/channel/UCxjA_NbeScQy9C0Z1xjwXpw
johnjmbennett
In addition you can stretch a series of beams/columns via their grips.
Select the beam/columns to be stretched, then hold down Shift and select grips so that they are highlighted. Release Shift and select a grip as the base grip by clicking the grip and move it.
Cheers
JB
John Bennett
