Message 1 of 9
Select bolts from selected bolt holes?
- Mute
- Permalink
- Report
Hi all,
I have a large model and need to change the bolt assembly (larger washer) for all bolts in slotted holes.
These are manual bolts, not from joint macros.
I can select all the correct slotted holes via "Search and Mark Objects", but this will only let me access the hole properties and not the bolt properties.
Is there a way to select bolts from selected bolt holes?
...I know you can do so from a single selected hole via "joint properties", which opens the bolt dialog, but if you have multiple holes selected, this is not available.
I can't search by bolt type as there are similar bolts without slotted holes and I don't want to change these.
Any ideas?
Dave Gronow
Drawtech Services Ltd
