I tried to set up a cut like the screenshot, but nothing happened. Was this added by hand?
Solved by Sebastian_Eiche. Go to Solution.
You had to add the endplate view in the drawing styles, I would just have a look in a normal beam mainpart drawing styles (like MP column)
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
What do you mean with Labels? "A-A" and so on?
This is a default:
Sebastian Eiche
