Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Rollover Tooltips weird behavior
8 REPLIES 8
Message 1 of 9
Julio_Soto
500 Views, 8 Replies
I'm trying to setup the rollover tips in the CUI and it works for some items and not for others. For example, ASTBEAM, I check all the properties under the "Section" Category and when I test it it doesn't work, but I do get the weight. When I go back to the CUI, the section properties duplicate itself, so I see "Profile, Section Class" twice. I checked them all again, and it still doesn't work. I go back to the CUI and now the category duplicates itself a third time. Does anyone have this issue?
8 REPLIES 8
Message 2 of 9
pendean
in reply to: Julio_Soto
Restart your computer.
Try it again.
if you still see the same issues, consider resetting your software back to defaults
Message 3 of 9
Ignus.E
Its a bit strange,  but when you have the rollover tooltips setup correctly, the trick is to hover over a beam first when you open the 1ste model of the day.(every day).If you hover over a plate 1ste you get that sometimes. But normally if you just restart Advance steel it will get rid off the duplicates.
Message 4 of 9
Julio_Soto
in reply to: pendean
gave it shot, still doesn't work. I'm going to try to just recover an old CUI
Message 5 of 9
Julio_Soto
It was easier to just recover the original CUI and start over. It seem to be working just fine now.  Last time I added a bunch of objects and started checking properties. This time I added one or two objects at a time and then checked boxes. So far so good
Message 6 of 9
Julio_Soto
in reply to: Ignus.E
That's interesting. I see if this is an issue going forward
Message 7 of 9
bigcarl5000kg
this is still a big problem ...
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
Message 8 of 9
Julio_Soto
Oh wow, you're right! This is a bit upsetting lol. I don't think I can blame AS for this, it's an Autocad issue I suppose.
Message 9 of 9
Ignus.E
At least with this method it can be avoided 😊
