Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Revit 2020 warning "A transaction or sub-transaction was opened but not closed"
2 REPLIES 2
4541 Views, 2 Replies
I use Advance Steel API to model member and joint in Revit. Code is working fine in Revit 2019.2. Now I recompiled in Revit 2020 using new DLL, setup similar to Revit 2019.2. Program is executed, I can debug and tract. I got warning "A transaction or sub-transaction was opened but not closed, All changes to the active document made by External command will be discarded."
Exactly same code, work in Revit 2019, but not Revit 2020. Is there something special in Revit 2020 I need change?
In same exe, Revit related commands works fine, but not those related to Advance Steel API.
As all Advance Steel expert are here. I post it here instead of Revit Forum.
Any idea or suggestion?
2 REPLIES 2
Sebastian_Eiche
Maybe this is better to ask in the Revit Forum or not?
Smiley Very Happy
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
ChristianBlei
there are changes to the API from AS2019 to AS2020.
A change is that you have explicitly commit a transaction now, otherwise the chnges will get descarded.
That is what the message is about.
So Do:
Documentmanager.LockCurrentDocument
Using transaction= transactionmanager. startTransaction
// do your stuff
transaction.commit
end Using
DocumentManager.UnlockCurrentDocument
There is a knowledgebase article   here  about these changes.
HTH,
Christian Blei
Christian Blei
CBT Christian Blei Tools
christianblei.de
youtube.com/channel/UCxjA_NbeScQy9C0Z1xjwXpw
