Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Revision control
1 REPLY 1
S.MANICKAVASAGAM
310 Views, 1 Reply
Revision control
Dear expert,
                   Can be edit or delete revision mark for multi drawing (two or more) in single stroke?
Thanks & Regards
S.MANICKAVASAGAM
FAB. DETAILER
My body Your body Every body is Just SOIL body
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
1 REPLY 1
Hi @S.MANICKAVASAGAM
No its not possible to edit the revision of multiple drawings, they need to be done one at a time unfortunatly.
There are some ideas already in the idea station for this, see below
https://forums.autodesk.com/t5/advance-steel-ideas/select-multiple-drawing-files-to-edit-revision-nu...
https://forums.autodesk.com/t5/advance-steel-ideas/please-make-revision-control-clouds-more-user-fri...
Rob Merriman, AEC Technical Lead, Graitec
