Renumber cut views 2018 bug
andrejpa
andrejpa
the _AstM9CommDetRenumberCuts command does not work correctly.
See screenshots.
1- before
2- after renumbering
Maybe problem with default on screenshot 3?
Emanuel.Nestor
Autodesk Support
Autodesk Support
Hi @andrejpa,
Thank you for reporting this behavior.
As you could notice, the issue occurs when the option for creating cut symbol for end plate views is activated and use the "Renumber cut views".
This issue is already documented and escalated to the development team, being under active investigations at this moment.
As workaround for now, maybe you could deactivate the option for creating cut symbol for end plate views, if it is acceptable.
Otherwise, I could only suggest to modify the cut view numbers after exploding the cut symbol (or the entire detail).
I hope this will help you for now, during the investigations. Thank you for your understanding.
Best regards,
Emy
Emy Nestor
andrejpa
Maybe note - after the update is the cut renumbered.
What the solution now?
Did they find why its bug?
Need a solution.
Emanuel.Nestor
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for your question.
Just checking, did you installed the latest update for AS 2018 --> Hotfix 2 ?
Normally you should receive different numbers for endplate views and section views after that.
If you have any other issue after renumbering the views, try first to update the detail.
Please let me know how it works.
Best regards,
Emy
Emy Nestor
alickomay
im using as19  and allso cant get this renumber cut view to do any thing
