Reidbrace bracing system
FordSteelEngineering
Hi guys,
The industry here commonly adopts Reidbrace as the diagonal bracing system.
The most similar system in my Advance Steel is to use tension rods, but I cannot find this supplier system in the library. The concern is that when using other supplier systems, the hole in the plate is not fit for the Reidbrace system, and the length of the rod is not fit as well. Is there any way to add a supplier system into my Advance steel?
Many thanks.
bigcarl5000kg
Hi @FordSteelEngineering ,
look at Management Tools / Tables and filter for "tension":
Here you will find existing supplier / products in 15 groups.
If you need to add another supplier / product and you have no experience with editing tables in Management Tools or via SQL Server, please add a new record to Idea Station: https://forums.autodesk.com/t5/advance-steel-ideas/idb-p/144
If you dare to make adjustments, your first option would be to adjust one existing product (which you will not use) in Management Tools to your needs ... but it's all about tuning 😎 (for experienced users).
For a new supplier (and product) you need to get via SQL Server (to create a new line with eg. RULE_TensionRods_SupplierTable16) and then the product parameters (for more experienced users).
Be careful. Tables are mostly linked to other tables.
HTH
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
bigcarl5000kg
For special needs, you have to create special parts, which probably won't be native Advance Steel objects (eg. solids) ... and it is necessary to deal with these in this way as well
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
