Reidbrace bracing system
Hi guys,
The industry here commonly adopts Reidbrace as the diagonal bracing system.
The most similar system in my Advance Steel is to use tension rods, but I cannot find this supplier system in the library. The concern is that when using other supplier systems, the hole in the plate is not fit for the Reidbrace system, and the length of the rod is not fit as well. Is there any way to add a supplier system into my Advance steel?
Many thanks.
