Rectangluar contour gap issue
sh.yuL6HC4
sh.yuL6HC4
For sensitive detail modeling and drawing in Advance Steel, when I create Rectangluar contour on flange of beam. Contour has 0.001mm gap. This is shown on modeling as well as drawings.
used software: Advance Steel version: 2021, International country setting.
Is it bug or possible to control setting in default?
Thanks for your help
1 elements cut 1.png1 elements cut 2.png1 elements cut 3.png1 elements cut 4.png1 elements cut 5.png
David Yu
Technical consultant
Linetek System
sh.yu@linetek.co.kr
http://www.linetek.co.kr
Sebastian_Eiche
This gap is not a bug, years ago we get the response from the development, that this minimal gap is  needed.
For some calculation a division by "zero" is not possible, so the some settings in Advance Steel are set to 0,0001mm. But this should not really have an influence in steel construction
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
sh.yuL6HC4
Thanks for your sharing, in case of working with machanical company, they are very sensitive of shapes and dimensions.
David Yu
Linetek System
sh.yu@linetek.co.kr
