Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Propagate Connection
3 REPLIES 3
ignacio_castilloCH4RN
224 Views, 3 Replies
i'm encountering a problem when trying to propagate a connection, it selects/connects the secondary beam in some cases, why is this? is there a primary/secondery switch button?? what i'm a doing wrong?
when i propagate this happens..
3 REPLIES 3
the propagate tool have a look for identical beams which are visible and have the same geometry.
In you case the order of selecting the beams is not working correct, because they are the same and the software dioesn't know which is the mainbeam (how should it know?)
the propagte tool is also looking for the modelrole, so for having a better result try to give the mainbeam a role which, then it will work
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Thanks for you reply i'll keep in mind the model role, another question is.. why are connection boxes in blue when propagating?? the connection is fine/properly copied, is there a meaning to it?
if there're blue boxes, there should be a message box before...something like "the copied joints have different geometric situation, should these be included the group or not"
And if you decide, to let them part of them group, the boxes are blue. this means the joints you propagte are in the group but they have a geometrical difference to the original one
Sebastian Eiche
Technology Administrators
