Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Problems with "Walkthrough: Creating Model Elements"
2 REPLIES 2
tiago.pereiraGB2J9
235 Views, 2 Replies
tiago.pereiraGB2J9
Hi everyone,
I´m a new user of C# and Advance Stell and I was trying to run the "Walkthrough: Creating Model Elements", but I found some errors.
When I ran the "NETLOAD" command in Advance Steel, it seem that nothing happens. I dont know if thre´s a problem in my Assembly file or the XML, so, I´m attaching these files here.
As it´s a helpful topic launched by Autodesk on April 4, I don´t know what´s wrong with my code. I only made some modifications to create only one beam/column.
Can anyone help me, please?
using Autodesk.AdvanceSteel.CADAccess;
using Autodesk.AdvanceSteel.DocumentManagement;
using Autodesk.AdvanceSteel.Runtime;
using Autodesk.AdvanceSteel.Geometry;
using Autodesk.AdvanceSteel.Modelling;
using Autodesk.AdvanceSteel.Profiles;
namespace HelloWorld2
    public class CreateElements
        [CommandMethodAttribute("TEST_GROUP", "CreateElements", "CreateElements",
                                                     CommandFlags.Modal | CommandFlags.UsePickSet | CommandFlags.Redraw)]
        public void Create()
            using (DocumentAccess da = new DocumentAccess(null, false))
                //create column (vertical beam) with a default size
                ProfileName profName = new ProfileName();
                ProfilesManager.GetProfTypeAsDefault("I", out profName);
                Point3d beamStart = Point3d.kOrigin;
                Point3d beamEnd = new Point3d(0, 0, 3500);
                StraightBeam myBeam = new StraightBeam(profName.Name, beamStart, beamEnd, Vector3d.kXAxis);
                myBeam.WriteToDb();
                da.Commit();
Hi everyone,
                myBeam.WriteToDb();
                da.Commit();
2 REPLIES 2
ChristianBlei
if the AddOns loading mechanism is working you do not need a netload.
what if you use the ADVS loading command ASTORLOADASNETPLUGIN?
HTH,
Christian Blei
CBT Christian Blei Tools
christianblei.de
youtube.com/channel/UCxjA_NbeScQy9C0Z1xjwXpw
HTH,
Christian Blei
christianblei.de
tiago.pereiraGB2J9
Thanks, @ChristianBlei !
It´s works! I´ve used the command ASTORLOADASNETPLUGIN and it´s work.
Thank you so much!
Thank you so much!
