Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Problems with generated railing drawings
1 REPLY 1
445 Views, 1 Reply
Hi all--
I have been working on a set of stairs and railings.  I have been able to figure everything out with some help until this morning.
The structure of the stairs is installed, so we are now working on the handrails.   I was able to create the interior railing using the --- RAILING UCS process.   everything worked great.  The created drawings are rotated the correct direction for the shop to build them.   The interior rails are built but not installed.
Today I started working on the exterior railings.   Yesterday I was able to create the long outside railing (the first one from the top), so I know the RAILING UCS is working on the longer railings.
When I try to create the drawing, I get an error that says " No Main Part Selected"   then the drawing is not created.
Any idea what has changed?     I will attach the model for you to look at if you want/ need it.
Thanks for the help
P.S.   I did not close the program last night, and during the night the program crashed.   I was working on another set of stairs
Steve
Hi all--
Thanks for the help
Steve
1 REPLY 1
I figured out the problem.    I did not number the parts on the railing.
Once I ran the number process, everything worked as normal.
Thanks for the help
Steve
Thanks for the help
Steve
