Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Problem with Drawing Style Preset
1 REPLY 1
331 Views, 1 Reply
Hi, I'm new here, I am using Advance steel 2020. I have a problem where whenever I choose a drawing style to create a drawing, the popup window doesn't allow me to change settings (labelling,etc.) only to choose templates. Other tutorial videos I watched has the feature, how can I enable that feature. Screenshot below. Thanks.
1 REPLY 1
Steel-User-GRTC-John-Bennett
This operation of the software was changed a few versions back, to the new interface.
so it is not possible now to do that via the dialog. ( which is a shame as it was so flexible when needed)
if if you need no labels, then you may have to venture into the drawing styles and copy a style, then change the labelling.  But that’s a bit of a jump in the deep end.
There are styles with no labels, but again it depends upon which country install is being used.
cheers
Technology Administrators
