Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
problem with drawing a purlin
5 REPLIES 5
870 Views, 5 Replies
Hello!
I want to draw purlins on my roof. I have a beam that is connected to another vertical beam. If I use purlin tool to draw purlins on top of that beam I have a problem with inclination of my purlins. I attached the file.
Help me change that angle or tell me how can I draw purlins on my beam?
5 REPLIES 5
CHRIS_ASDL
If you delete the connection between the column and the rafter the purlins will then align correctly with the rafter.
Kind Regards
Chris
Kind Regards
Chris
Yes, but if I make that connection back it will change back to what it was before - not aligned with the beam..
johnjmbennett
The reason that this will not work correctly is that the beams used in the model a polybeams to from the vertical and incline beams,  one polybeam.
The purlin insert macro was not designed to work with this beam type in the configuration that is in the model.
polybeams where created in AS to create strange curved, spline type arrangements,  ones that are reasonable straight forward, you would model as normal Advance Beam elements.
  1. Remodel the beam as  vertical column section, then a AS Beam for the rafter line.
  2. Use the mitre joint on the AS palette , under feature tab to created the joint between the two sections.
  3. Then reapply the purlin macro.
  4. note to select the column as reference  beam object for the eaves beam alignment.
updated file returned.
http://autode.sk/2u2O6IC
John Bennett
johnjmbennett
polybeams where created in AS to create strange curved, spline type arrangements,  ones that are reasonable straight forward, you wold model as normal Advance Beam elements.
John Bennett
Hi @Anonymous,
As you can see in the photo atached.  The column is not aligned with the vertical  Axis , ( in this case "Z" ).
For this reason ( because of the beam is united to the column , and the column has  a diferent direction of the vertical axis "z" ) is the desviation ocurring. If you put the column exactly in the same direction than axis Z  I guess the problem will solve.
Jon.
