Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Precise weld length on the drawings
1 REPLY 1
steell_zevallos
203 Views, 1 Reply
Receive a warm greeting;
I have a problem when generating the default welds that I place when modeling, because as I show in the attached image it comes out with a precision of 4 decimal places and I need it to be exact, I would like you to help me where I can configure so that this does not happen , thank you.
1 REPLY 1
Hi @steell_zevallos,
you need to set the length precision in the Project Data (command _AstM4CommProjectData) bigcarl5000kg_0-1678782651407.png
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
