Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Pop Up Message, when starting Advance Steel
2 REPLIES 2
shubham_shri
322 Views, 2 Replies
Hello Everyone,
      I have recently installed advanced Steel, whenever I try to run this program, following message pops up
Kindly help in resolving this issue
Shubham Shrivastava
Autodesk Certified Professional for Revit Architecture
If you find my post helpful, feel free to give Kudos
2 REPLIES 2
AntDrt
in reply to: shubham_shri
Hello, in AdvanceSteel 2021, there is some problem at launch
check this topic and especially answer from @stephan.gumpert
https://forums.autodesk.com/t5/advance-steel-forum/2021-update-cannot-access-databases/m-p/9446044/h...
if you have still issue, check the version of your SQL server
and follow steps from my answer: (last reply on page 1)
https://forums.autodesk.com/t5/advance-steel-forum/2021-update-cannot-access-databases/m-p/9436477/h...
hope it helps.
Antoine
AMG Fechoz
Serrurerie & Equipement Scénographique
www.amg-fechoz.com
stephan.gumpert
in reply to: AntDrt
Replacing the xml file in this case will work. 🙂
