Please fix the Polybeams representation
acbsdesign
Mentor Mentor
Message 1 of 10
acbsdesign
Please find a way to fix the polybeams representation on dwgs, below are a few examples of how top rails look like when not exploded to two separate polybeams:
08 07 19 -1.jpg08 07 19 -2.jpg08 07 19 -3.jpgTop rail is one beamTop rail is one beam
Thank you,
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
Replies (9)
Message 2 of 10
Sebastian_Eiche
this problem only occurs, because you create a polybeam with a 90 degree connection...what is not possible to produce.
I recreate the situation and only "parted" the polybeam on this point. Then the result is much better.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Message 3 of 10
acbsdesign
Yes, this is what we do, we explode the macro and cut the top rail and join, and representation is ok, but it has to be fixed.
Message 4 of 10
Sebastian_Eiche
I think this is a problem of the  model.
The railing had to be parted in two railings, because this 90 degree point in the handrail could not be produced.
So the it had to be two railings which are welded together, or the 90 degree point had to be changed to maybe an elbow.
Both, bentbeams and polybeams, could not be produce without a radius in this installation situation. So maybe this is "hidden" help funtion from Advance Steel for: "be carefull, there could be a problem", like if you use a 0 radius for folded plates, then this line is often don't shown in the detail.
Sebastian Eiche
Message 5 of 10
This is a trap with the Polybeam tool. So many new users (not meaning you Ilko) use this tool and get one beam with mitres, looks good but it doesn't make for correct drawings, numbering etc and fabrication is impossible. I advise new users only to use this when there are bends or curves in the beam, model it as you would make it.
Gary
Message 6 of 10
JMNTibs
Unfortunately, I think that this has something to do with AutoCAD's inability to produce a 3D polyline with arcs.  But yes, this is something that should be addressed.  We often have rail bends in different planes on a single piece of material, but I can't model it that way.
Message 7 of 10
Sebastian_Eiche
you could model it by using the railing macro, but you could not use miter connections. If you use the "knee" connection type in the "handrail- handrail" tab, it's possible to create a polybeam.
But as wrote in the first post, then detailling of the polybeam is not so nice, because of to much lines
Sebastian Eiche
Message 8 of 10
Sebastian_Eiche
maybe additional.
I made some test with the object representation and get the result, that if we use the Color "Exact Default" it looks a little bit better in some cases.
So I add a new model object representation for polybeams in the GA detail style, and create a copy of a presentation  (maybe just use "visible") and then I change it to "exact default"
In my cases it reduce the line maybe about the half, but not so good, as I would split the beams
Sebastian Eiche
Message 9 of 10
acbsdesign
@Sebastian_Eiche wrote:
maybe additional.
Thank you for your time,
We will give it a try.
Message 10 of 10
mdmcano
This always works for me
