Platform plate connection
jamtP8KNT
jamtP8KNT
Hi guys,
I would like to put the plate inside the column in vertical as is shown in the  small window . Somebody  would know how to do it? I did not find the option.
Thanks!
jamtP8KNT
May be I am making a mistake when I select the option for this element. Because the vertical beam is a column and that option is for horizontal beams....for plattform....Would it be posible? Which option would you use for my example?
robertwmerriman2
Hi @jamtP8KNT
In the connection you have a tickbox for "In between flanges" see attahced screenshot.
Rob Merriman, Technical Specialist / Principal Structural Designer, OLG
jamtP8KNT
Sorry, may be I did not explain it correctly. See in the next screenshot what I mean. Thanks for you efford
