plate not being detailed with other plates
alickomay
alickomay
is it not a plate with role end plate.PNGrecording.PNGplate draw proces deta style map.PNGcopy(4) plates 1of2.PNGcopy(4) plates 2of2.PNG
im strugaling to get this plate detailed with plate drawing style
the plate is 60x10 and got same problem on a 70x10 plate
so thay could be seen as flat bar
but i turn off recording
allso i added beam /end plate to copy(4 ) plates  , am i rite that a bit of flat bar is a beam to AS
this problem dose not happen on 60x8 an 70x8 plates
alickomay
im been triying to figer this out sum more
and it seems that most of my 10x70 an 10x60  plates are being detailed by plate drawing style
all 3 plates that are not being detailed  by plate syle  are model role= end plate
but i just found a 70x10 and 60x10 end plate that is detail by plate style
bad plates  f2/11 ,10*60     f1/13 ,10*70   f1/17 ,10*60  all end plates
good plate  f1/12 ,10*70 , base plate       f2/16 ,10*60 end plate       f1/17 10*60 end plate
crydee-AG2
I have tried making drawings from your model with the the 2019 Advance data set and they all sue 2011 Single Part plate style as correct. Have you tried using the advance styles instead of user ones? It must be something weird in your user styles.
Aleck Giles,
LinkedIn
Autodesk Certified Instructor - Gold
alickomay
hi thanks for reply
i deleted all plates then ran drawing sute "advance "
all plates are detail the same now
iul have look throw my seting tomorow cee if i can figet out y sum plates are not detail with others
alickomay
so i see the advance settings  had plate model role just as  plates/all model roles
so i added all model roles to my plate definition and now all plates detail with same style
on one job this made sense as i didn't have a role in the list (t plate)
but on the job i uploaded  thay are end plates with model role end plate  witch is in the list of plate roles  so i dont know y it didn't work
but not to worry it working now with all model roles
i think i didn't have that in list  as i didn't won't  cover plates and checker plates  on multi drawings but i could make a drawing style for them and put it in suite be for the other plate style
