plate cut issue
plate cut issue
St.Jordon
Message 1 of 10
plate cut issue
St.Jordon
one folded plate cut another plate with arc chamfer, i want to get the correct shape of the folded plate , also the correct expanded drawing.
when i do this opration,  it cut a straight gap, see the following picture, any one who can tell me how do i deal with this?QQ截图20180613164657.png
Jordon
Replies (9)
Message 2 of 10
robertwmerriman1
Can you upload your model please and i will have a look and see what i can do.
Rob Merriman, Technical Specialist / Principal Structural Designer, OLG
Message 3 of 10
St.Jordon
Thanks a lot, sir.
pls see my model .  by the way, the arc edge can not chamfer,so i used a polyline instead the arc line, do you have some comments about this or any other methord ?
Jordon
Message 4 of 10
alickomay
re uploaded model made  cut with a poley line that i made from snap points on the "cad solid" cut that u had dun
so used snaps  to make poley line
then copy that poly line to the AS plate
and then used polygon cut contor ucs / see pic
its a straight cut so tight one side  , bit gap other
Message 5 of 10
alickomay
Message 6 of 10
alickomay
so it dident let me post evry time i clik post  nothing hapens
i thort my be it because im triying to upload a file with same name as one thats there
so i remove  cut.dwg
change file to cut ao.dwg
then it let me post
but now u got the first post  plus the second dosent have cut .dwg removed !
Message 7 of 10
robertwmerriman1
Hi, my solution is very similar to Alick's but i use the clash check marking to get the shape for the polygon contour. I have recorded a screencast and the link is below.
https://autode.sk/2laCkK9
Message 8 of 10
alickomay
that may be beter as i never made the poly line i copy all redy dun work   if u can make if with out haveing to make sum other autocad solid part  shorly be faster
but i think u fugot to upload model
Message 9 of 10
alickomay
that screen cast was not ther when i first read  definely sumet a bit weired going on with fourms to day
but yer that solution much better
i will be useing that work flow fora more advance cut at object in future
Message 10 of 10
St.Jordon
Hi, sir.  do you know why an arc edge can not be chamfered?  any other way to do this except use a polyline instead of arc edge.
Jordon
