Hello everyone,
I'm trying to place holes on an inclined plate but they are offset to the bottom of the plate, as shown on the screen-shot below.
What am I doing wrong?
Hi @Anonymous
When modelling holes your the XY plane of the UCS needs to set at the same level of the plate.
If the plate is at an angle then the UCS needs to be set to the same angle.
The move UCS and UCS at object can be found on the UCS tab. For the UCS at Object make sure you can see the whole object on the screen before using the command.
Rob Merriman, AEC Technical Lead, Graitec
Hi @Anonymous
I suggest put the UCS on this plate with UCS by three points...and repeat the command...
I hope it helps
- Marque "Aceitar como Solução", caso tenha resolvido seu problema.
- Select "Accept as Solution", if it has soplved the problem.
- Clique em "Curtir" se a resposta ajudou.
- Click on "like" if the answer helped.
Antonio Dias
|Linkedin|Instagram|Facebook|Twitter|YouTube|
Colaborador da Comunidade de Usuários Autodesk Brasil
