Placing Commands From The Tool Palette On The Quick Access Toolbar
doverend
doverend
Is it possible to put commands from the Advance Steel Tool Palette on the Quick Access Toolbar?
David
acbsdesign
In order to see the command text in AS palette, please open   AstPaletteData_User.xml file in
Steel, Support, Toolbars folder
Copy the command text and create a new command per post 22 of this thread:
https://forums.autodesk.com/t5/advance-steel-forum/advance-steel-custom-commands-share-your-ideas/td...
After that drag the new command to a toolbar, it should work.
Have a great day.
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
acbsdesign
For the Quick Access Toolbars-it works same as a std toolbar-by dragging from the cui menu ditecly in the toolbar on the screen, or by dragging to the panel  "Quick Access Toolbar X" in the cui menu.
