Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
PEMB eave beam / purlin
1 REPLY 1
muleman1
974 Views, 1 Reply
I am trying to create an 8 inch pre engineered metal building eave purlin / beam. I simply cannot find any combination in the purlin macro to get it to work.... will I have to create a user profile?? These eave purlins are on 100's of 1000's of PEMB, surely I am overlooking something very simple ??entry eave beam 1-25-15.jpg
....How easy it is to acquire knowledge, yet how difficult and painstaking is the process of gaining wisdom. .... Chuck Swindoll
1 REPLY 1
wtheron
in reply to: muleman1
Hello Muleman, I don't believe that that is possible inside the macro unless you have created such a profile as user section. Then you can specify eaves beam in macro. User Section could be challenging as you would need to create on for each pitch of rafter you use.
I would recommend exploring folded beam profile section as an alternative.
