PDF showing up in GA drawings
I imported a PDF into a model. I drew some components around the detail. I was wondering if it is possibe to get the PDF to show up on my GA drawings? Does any one know the answer to this?
Priitl220
No , the pdf will not show up.
You can add pdf manually to drawing, as you added it to your model.
____________________________________________
If you find my post useful give me Kudos. Thank you!
If my post solved your problem, accept it as a solution.
vlad.capraruH4T4S
Observer
Observer
When importing the PDF file, you can choose to import it as a block (if the PDF is vectorized and not a scanned image). This will convert the PDF items into 2D elements. The block will show up in the drawing.
xavier.finta
Observer
Observer
@vlad.capraruH4T4S Which layer does the block need to be on for it to appear in the drawings?  I'm still having no luck with this.
AleckGiles
The block does not need to be on any special layer. Presuming you use Cameras to create your GA views you need to tick the Default "Drawing general > General > Allow detailing of CAD entities in Camera Views". Then any AutoCAD objects within the camera scope (including your block) will show in the resulting view. You can turn the Default off again afterwards. The state of the Default does not affect updates as each view knows the status when it was created.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
Autodesk Certified Instructor - Gold
