Partial Bend Lines
Partial Bend Lines
mitchell8TKBM
Partial Bend Lines
mitchell8TKBM
Is it possible to export DXF plates with Partial Bend Lines. I have manually modified the plate in the attachment to show what advanced steel exports and what i want it to export.
j.hamelin
I want to know! 😁
Mechanical Design Drafter
If this information was helpful, please use the Accept as Solution function, this make it easier for other users.
bigcarl5000kg
Hi @mitchell8TKBM,
... there you can set multiple things for bend line in DXF. For your case you can set the Linetype as needed.
The same settings are available also in Management Tools:
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
mitchell8TKBM
Thank you. Do you know if you can set the linetype scale?
