i thought i had this figured out in 2015 but now in 2016 i cant seem to get the same results im wanting.
i'm trying to get the main assembly mark for a beam to look like this. (1B1) where the 1 represents the current sheet, B is the prefix and the last 1 is the counter.
so sheet 2 would be (2B1).
the single parts i got to look like i wanted with the prefix and then the counter number.
all i can get right now for the main mark is (B1).
I've tried every combination i could think of. any thoughts?
You will need to generate the drawings then update your numbering to get the sheet number to show up in the number itself.
Thanks Jonathon,
but it actually turned out to be something else.
since i was testing the system and trying different settings to get what i wanted, the system database somehow got "gummed" up. I copied the model to a fresh sheet and then tried the settings i used before and everything worked fine.
