Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Pan Not Working while Zoom function in Advance steel
3 REPLIES 3
775 Views, 3 Replies
In Advance steel Pan and Zoom using mouse function working together in Normal.
When we select anything like pick point by running a connection , select Object by running a View function, pan totally not working. Zoom only working. Picking a point or object in this condition is required more mouse button scroll.
I dont know any system veriable we have to change to acheive this?
Pls Help.
http://i.imgur.com/iKmZ4Px.png
3 REPLIES 3
Bogdan.O
Hi rashlak,
While in a command (besides panning with the mouse wheel button) you can also use the Pan button from the Navigation Bar (under the View Cube).
After panning, hitting once Esc returns you to your command.
If you are still having problems, I would kindly ask you to record a video using Autodesk Screencast and share it here.
Bogdan.
Bogdan Orzea
QA Analyst
in reply to: Bogdan.O
Please see this video
Bogdan.O
Thank you for the video you shared. It will help us investigate this behaviour.
EDIT:
You can also create Model Views by using the button from the Ribbon. Pan and Rotate should work if you start the command this way.
Rergards,
Bogdan.
Bogdan Orzea
QA Analyst
